I have an R32 GTS25. I have fabricated a 2.5 exhaust to go from the exhaust manifold all the way to the end. At the moment it is just straight pipe. Obviously it will be too loud as is.
I am thinking about having one Coby Resonator in the middle. Then a RPS Cannon muffler at the back.
My question is wil this muffle the sound a fair amount? and will it reduce the sound of the ugly fart cannon sound N/A skylines have?
Also do the angles of the pipes make much difference to the sound? Because there is a skyline who lives around me and he has the same system i described and i want it to sound the same as that. But i dont want to have to get his car to compare and have exactly the same laugh.gif
Any help will be appreciated :D Maybe someone who has done a 2.5 exhaust on there car and knows what is sounds like.
https://www.sau.com.au/forums/topic/375465-exhaust-for-an-r32/
my exhasut from japan is all sorts for a N/A, 2 1/4 inch to 2 1/2 then a 3inch part then back to 2 1/2 inch
Havent bothered to dhange it and i dont get any drone at all, actually sounds nice. a bit loud yes but thats how i like it.
i theres only only way to find out, just intall it and make changes after you hear it ect.
Angle of the tip makes absolutely f**k ALL difference, screw your head on..
Get two good oval mufflers from your local exhaust shop, ANY cannon on ANY n/a skyline will sound heinous, with an N/A you want quieter, or else you will be back on here making a new thread asking why your car makes a rasping noise at 3000rpm or so.
Cheers for the help. Im going to go source me two nice 'hot dog' mufflers to point in the system. Have you had hands one experience with the sound?
I have actually got a GOOD quality exhaust tip on the standred exhaust system atm. Sounds great. No raspy sound at 3k
I'm running 2.5" mild steel with a small muffler mid way through, then from the diff back I'm running 3" straight bit of stainless and on top of that I'm running a decat pipe too.
Sounds bloody awesome, couldn't be happier.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
