Import Monster Sau-Vic Deca - Round 3 2011 Wrap Up Thread
Fantastic weather and fantastic day bar a few negative moments...volunteers should really be clearer on the rules...hope everyone had fun and hope those with mechanical issues can get them sorted soon...
I guess I should be happy with a 3rd in rwd.... :/
If your not having fun at DECA don't go.
If having a sook about volunteers and having a cry about coming third is what your into, no one will miss you anyway...
  • Replies 112
I know its tough being a volunteer and even tougher being an organizer...i know because i've run a deca day before and will be running another one very soon...being at the pointy end of the field this year makes it a little more important to me...you don't know the details of my day so i won't expect you to understand and won't take your comments to heart too...
Ultimately I appreciate the fact that these days are still happening and will continue to support SAU VIC in their events...this is the only level of motorsport i take part in at the moment so don't fault me for being passionate about it....
We're not talking high level motorsport here man...
We are only using manual timing so there's nearly 1/4 - 1/2 a second just in a button press. You don't see people 'at the pointy end' complaining about 0.5 sec inaccuracies.
sometimes 0.5 is all that seperates the top 5 or 10 times and a few of them could add up to 31 points :P
Anyway. I love the competitive side of it so don't think I'm playing down the 'competition' of it all, it makes it more fun. Ryan and I have been dualing at decas for a long time in similar (well used to be similar) cars and to be honest that is where the real fun is. I've had incorrect times in the past but it's only club level motorsport with volunteers standing out in the sun for us! Get over it. Don't even mention it.
Agreed Russ...its entry level motorsport and meant to be fun...but those 31 points could end up really handy right? lol...i know i could use about 20 or so points... :P
For the record I was contesting a questionable penalty in the region of 5 secs but the event is long over and theres nothing that can be done about it now...the organizers have tried to address it and thats all I can ask for...
The last round should be interesting....
You should probably consider yourself lucky then I didn't penalize you for not stopping in the gate properly in one of the battles...
Thanks guys!
I thought his was slightly darker than that one-must just be the pic
haha, Steve, that's my car :)
Those pics do make it a bit lighter than it is i think, this is probably more accurate
http://i275.photobucket.com/albums/jj294/chinny83/midori_3.jpg
And John, didn't even realise i was talking to you the whole time!! haahah, nice to finally meet you. Been watching all your track vids and what not.
Thanks for those that took pics and videos. Ryan and Russell, driving skills are just fantastic to watch, especially your battles on the pan. The sil80 was just smooooth and the 32 was just banshee style... loved it!
Supra, impressive driving. Mark, in the 944, very impressive. Lots of great drivers and the RS5 was silly quick and nimble for such a big car!
Tip for those re: tyre pressures on the skid-pan... don't run 40+ psi like i did... :blush: - i dropped to about 37'ish i think for the arvo events, and it was much better. Probably the only one silly enough to go that high :D -
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
