Nissan SKYLINE BNR32 GTR GODZILLA 1990
My Tidy and Clean R32 GTR is for sale, car is in A1 condition, comes with afew tasteful mods
Gun Grey - Polished paint, Shines like a mirror in real life
LMGT2 Nismo Wheels - Black with Chrome lip, Tuff bridgestone RFT
HKS Hyper d Adjustable coilovers
Exhaust - Apexi front, 3.5 " jasma cat back
Viper Alarm System - 2 Remotes
Stereo - 15 " sub box amp Clarion
Brilliant Condition, Serviced with Motul oil every 2oookms, Very Quick Very Reliable
Work done at FlowCraft @ deerpark , Eugene's best in the west ! 15ooo ago
JE Forged Pistons (NesCar pistons)
Nitto Oil pump ( Croydon Racing, better then N1 )
New exhaust valves, Metal Head Gasket, all new nissan gaskets and seals
New Water pump, timing belt, bearings, crankcamseals,
Big Alloy Radiator, HKS Intercooler piping, Blitz twin bovs and more
Car still looks very tidy and clean sounds brilliant and a joy to drive $20,000
117, ooo kms
last dyno'd years ago at chasers for timing issue, ran 233atws 307hp
not sure what its got now, but i run about 12-13 psi daily .. pleasure to drive at that boost range Brilliant
Exedy Cushion Brass Button Clutch
Edited by TwentySix
  • 3 weeks later...
Car still looks very tidy and clean sounds brilliant and a joy to drive $18,000
Just to be clear the rebuild was done 15,oookms ago - yes?
Original Turbo's ?
steel wheel rebuilds.
runs factory boost daily around 12 psi , driven conservatively .. not pushed, only on cold nights
GODZILLA R32 GTR $18ooo
  • 3 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
