Nissan SKYLINE BNR32 GTR GODZILLA 1990
My Tidy and Clean R32 GTR is for sale, car is in A1 condition, comes with afew tasteful mods
Gun Grey - Polished paint, Shines like a mirror in real life
LMGT2 Nismo Wheels - Black with Chrome lip, Tuff bridgestone RFT
HKS Hyper d Adjustable coilovers
Exhaust - Apexi front, 3.5 " jasma cat back
Viper Alarm System - 2 Remotes
Stereo - 15 " sub box amp Clarion
Brilliant Condition, Serviced with Motul oil every 2oookms, Very Quick Very Reliable
Work done at FlowCraft @ deerpark , Eugene's best in the west ! 15ooo ago
JE Forged Pistons (NesCar pistons)
Nitto Oil pump ( Croydon Racing, better then N1 )
New exhaust valves, Metal Head Gasket, all new nissan gaskets and seals
New Water pump, timing belt, bearings, crankcamseals,
Big Alloy Radiator, HKS Intercooler piping, Blitz twin bovs and more
Car still looks very tidy and clean sounds brilliant and a joy to drive $20,000
117, ooo kms
last dyno'd years ago at chasers for timing issue, ran 233atws 307hp
not sure what its got now, but i run about 12-13 psi daily .. pleasure to drive at that boost range Brilliant
Exedy Cushion Brass Button Clutch
Edited by TwentySix
  • 3 weeks later...
Car still looks very tidy and clean sounds brilliant and a joy to drive $18,000
Just to be clear the rebuild was done 15,oookms ago - yes?
Original Turbo's ?
steel wheel rebuilds.
runs factory boost daily around 12 psi , driven conservatively .. not pushed, only on cold nights
GODZILLA R32 GTR $18ooo
  • 3 weeks later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
