Only if this was in nsw ...
Consider that it wouldn't cost you much at all to fly down to Melbourne to take a look at it. And it'll only cost you two tanks of petrol to drive it home... [bTW, I'm not related to the seller in any way/shape/form, just pointing out the obvious.]
To the OP, best of luck with your sale. I think it's a very fairly priced R32 GT-R and if it wasn't grey, I most likely would've already taken the trip down to Melbourne to inspect it by now.
thanks man, very hard to find a R32 GTR in clean and unmolested condition historic car
Does it cost/trouble much to register a VIC GTR to have NSW number plate?
and what's normal transport cost to bring a car to Sydney?
Edited by kor_gtr32
you will need a blue slip done (only costs about $50 i think). Transport will vary depending which company you go to, but i got a car transported to syd fron WA and it cost only $700 or so.
  • 2 months later...
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
