Only if this was in nsw ...
Consider that it wouldn't cost you much at all to fly down to Melbourne to take a look at it. And it'll only cost you two tanks of petrol to drive it home... [bTW, I'm not related to the seller in any way/shape/form, just pointing out the obvious.]
To the OP, best of luck with your sale. I think it's a very fairly priced R32 GT-R and if it wasn't grey, I most likely would've already taken the trip down to Melbourne to inspect it by now.
thanks man, very hard to find a R32 GTR in clean and unmolested condition historic car
Does it cost/trouble much to register a VIC GTR to have NSW number plate?
and what's normal transport cost to bring a car to Sydney?
Edited by kor_gtr32
you will need a blue slip done (only costs about $50 i think). Transport will vary depending which company you go to, but i got a car transported to syd fron WA and it cost only $700 or so.
  • 2 months later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
