So after having a pod on the 33 for like 4-5 years I've decided i want to revert to standard like it was before i did all the mods and see which is better. (the pod was the first thing i did with the car)
has anyone got any ideas on how to fit an intake for the air box as the stock snorkel won't fit due to the crossover pipe from the aftermarket intercooler being in the way.
Please post pics or ideas if ur running stock air box with aftermarket fmic.
Ur help is appreciated!!!!
https://www.sau.com.au/forums/topic/375549-switching-back-to-stock-airbox/
You just need to modify it a little bit to fit.
There is a thread on here where someone did just that.
Id search for it, but i pwnd my bandwidth and everything takes friggin ages.
From memory, he cut the section of the snorkel that fouled the intercooler piping out, and plastic welded a piece back in to clear it.
A couple of options, one is to modify the snorkle to go over the pipe, another is to turn the lid 180 so the intake is facing away from the engine, another is to do what i did and put a modified r31 snorkle on the end of the air box facing the head light.
In your situation i would go with 2 or 3 and then also add a pipe out of the bottom of the airbox and down through the vacant factory intercooler hole with a pod on the end of it.
Just cut the back of the snorkle with a hacksaw and then used some roof flashing from bunnings as it is very plyable. (like lead) and the used araldyte to stick it. Not really that hard as I am not that skilled.....
Dazza
Dazza
Actually i used a jigsaw then just filed it smooth and araldyted the tin flashing as it soft as and you can bend it concavely to the curvature of the intercooler pipe. Its very easy. I was only concerned with if i was losing too much air from the intake. its actually isnt that much though.
Give it a go. its not hard and I am not very handy & its didnt turn out too bad...
Dazza
  • 2 years later...
I decided go back to stock on my BNR32. I have a friend that has a 1990 BNR32 and he's willing to switch out parts with me. I currently have some sort of "M's" pod K&N filer setup:
I want to trade out with my mate's stock box:
Do the MAFs look different in size? I don't see the RED part on mine so I'm not sure if I can do a straight swap without ECU tuning. However, these are relatively old pix so I'll open my hood tomorrow and take a peek at my MAFs. BTW, I'm currently running a MINE's ECU which is in crazy need of a tune. Do you guys think I can trade parts and still drive around without tuning?
Also, I checked my Nissan FAST and what are parts: 16577 and 16580T (BOTTOM-LEFT)?
FAST says "DUCT ASSY-AIR" for 16577. Doesn't look like theres an opening that allows air to be sucked-in. Isn't that part right below the headlight that intakes the outside air?
FAST says "RESONATOR ASSY" for 16580T. What's the purpose of resonating the stock airbox and do I really need it?
Thanks.
Edited by CrimsonLey
Your Mines ecu is likely not tunable. Get a Nistune if you can.
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
