I got a set of Supertech RB25det springs and retainers to suit hydraulic lifters and I just installed them all and found an issue with them.
Im using standard valves and collets and with the kit installed, Ive found that the majority of the valve tips are not protruding above the retainer. Maybe 10 out of the 24 are protruding, though varying heights which isnt too much of a drama as the lifters will take up that. But the rest of them are all flush or below, some quite abit below. One that was particularly bad I fitted the factory steel retainer and the valve tip height jumped back up to where it should be. Some quick measurements show the titanium retainers dont have the same taper in them as the factory items. The taper is slightly larger in diameter so the retainer is sitting higher then what it should when seated around the collet/s.
Has anyone noticed this before? Or am I just unlucky and got an out of spec kit?
Try to get some photo's of how far out they are and get in contact with whoever you got them off. Quality control must have been out on a picnic the day they got made.
Yeh I will do that. But I dont have time to send them back and wait for a reply and or new set to be sent out. I can either make new ones myself or just refit the factory ones which seem to fix the issue which is my quickest and easiet option.
In case anyone wants to know, the factory retainer weighs 12.97g and the titanium retainer weighs 8.21g. Thats a good 4.76g saving per retainer and 114.24g saving overall!
  • 4 months later...
Hey mate have you had a look at the solid lifters you got off supertech did you get ones to suit the oe hyd retainer very keen to see how supertech decided to hold the shim in with the lifter rather than a rb26 which the retainer houses the shim
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
