  • Replies 54
Then R35 hands down.
Unless there is something about the R34 that you really must have????
I guess the performance of R35 is in a different league to the 34,
however............... i would still love to own a R34 as well! :)
Its just the raw sexyness and reputation and that keeps bringing me back to the R34.
Yes, Ive also heard you have to dump tens of thousands in to A R34 to bring it up to match the R35 performance.
But I want a R34 as close to standard as possible and I'll hold on to it. Already getting hard to find one which hasnt been 2 worked.
Stock for stock, the 34 is nowhere near the level of a 35.
The 35 is also the only car that has put a smile on my face without a clutch pedal, going from 35 back to an rb model you really feel the age of the 'old' gtr's.
For reference a stock 35 gtr does tsukuba in same time as z tune 34, which is regarded as the best goin street 34.
34 wins on price an maintenance though, unless u do it up you will not have maintenance costs like u see from r35.
For everything else, but pointless back seats, the 35 wins imo. So easy to drive, so fast, no lag, torque in any gear ( an amount you can only dream of from a rb ) great handling etc.
If money is not a problem I'd pick a r35 if I was you, the hype on them is well justified!!!
What cars are you coming from?
Hello, R33 GTR, R33 S2 GTST, 5x R34 GT-T, V35, Evo VII, Mercedes W211 E500, 350Z convertible, 350Z coupe. Thats all i can think of at the moment.
What i observed is the older nissan cars I've owned seemed 2 be better build quality than my newer nissans that ive had.
With my V35 and both of my 350z's I was getting sick of the power window faults, central locking faults, weak gearbox synchros, tears in the roof of the convertible - etc. All from design faults and sh*t parts. And u replace them with genuine spares which are also sh*t parts and its only a matter of time before it happens again.
With R34 u know the design faults already (stuff like rust around boot brake light). Im hoping that these similar issues i mentioned above dont pop up in the R35 over the next few years.
But R35 is such a sexy car aswell, they look fantastic every time i see them.
1318288390[/url]' post='6054986']
as a hobbiest detailer i couldnt fathom having my cars washed by low paid indian students, but then again everyone has diff priorities in life and some have other things to do instead of busting out the karcher etc on a weekend
nor would i simply high pressure the panels and then wipe all the dirt into the super soft nissan clear coat with a shamwow
op if you want someone to look after your car, shoot me a pm, i can recommend you a mobile detailer in your state who will do an at home wash
Would it be okay if they were low paid white-skinned students dominoz?
much respect to the R34 but you need a ride in the R35 - its godlike in every way
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
