Hey guys yes VCT is turned off it was
Dropping off at hi rpm now it has another kick
He also said that the front pipe an pod are holding it back...
Peak power is more likely to be held back by your fuel system than your front pipe and pod. VCT can be turned off mid way through, so have it on until 5000rpm to boost your torque up to that point (you're definitely missing torque out down there), then turn it off to ensure that it maintains the same high rpm power you are currently seeing.
The reason it feels like a stout kick up high is before its lacking the torque the motor could be making up until 5000rpm, the engine is designed to rely on VCT to have a good spread of torque - you're potentially missing out on ~10% of the torque you COULD be making at 4000rpm, which you'd definitely know about.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5993328
Was it fully tuned with it both engaged and disengaged? Dynoing with VCT off in areas where the engine is tuned with it on - or vice-versa, means that the tune will be off for the current state which could give a misleading indication of where the curve intersection point should be in an ideal situation.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5993425
When you say fully tuned, do you mean an individual tune either way? The comparison was done on mine with only one tune, the current one. I lost 20rwhp in the middle from having it off. It made no difference above 3900 so that's where we left it.
Also, DVS JEZ mr nissan would have worked out the vct switching point based on a car running 5 to 7 psi through a stock turbo with an entirely stock car. Its possible that when a car gets everything on it swapped over from the computer to the tailpipe that it would have a different vct switching point.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5994661
Mr nissan would have spent alot of time working out the best VTC switching point
Probably, but when we are tuning non-factory setups with non-factory ECUs we don't have the luxury of using whatever rules Nissan implemented - nor can we be assured that they are calibrated to perfectly match whatever deviation we have from what they designed in the first place. We can't even be sure that they had our best interests (ie, powah!!) at heart, I know of other manufacturers definitely making decisions on this kind of thing based partly on how "exciting" it feels (often at odds to the outright best performing), emmissions, fuel consumption as well.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5994746
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
