hey guys, so my 32gtst has a squeeling noise when on boost, ive never heard a boost leak before and would like to know what you guys think?
it has a hks gtrs, plasmaman inlet plenum, power fc etc..
www.youtube.com/watch?v=0DlWQGKmorE&feature=player_profilepage
it you guys could help it would be amazing :) and yes i have looked, had the plenum off twice, checked all the intercooler pipes, i just cant find anything :(
cheers
Edited by tp1gts2
https://www.sau.com.au/forums/topic/375671-rb20-boost-leak/
Recent threads like this have all leant towards an exhaust leak. Usually manifold-turbo gasket, but also possibly the head-manifold gasket. Especially if you have broken exhaust studs (which it is almost impossible to imagine an RB20 not having any of).
Even if the manifold studs are broken i try to avoid fixing them till they leak. Its amazing how long the gasket will last.
https://www.sau.com.au/forums/topic/375671-rb20-boost-leak/#findComment-5991515
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
