  • Replies 160
went today to the apple peel car wash to get a cut n polish and was speaking to the owner, and long story short he doesn't want any meets organized there anymore because he reckons mums call up saying there intimidated to wash there car at 9:30 at night because there's a group of people
Who gives a shit, wouldn't be the same if we didn't meet there!
I don't think losing $10 from a few people that get "intimidated" is going to affect his pocket one son owns a e55 uncle that was there had a Porsche 911 brother had a m5 dad owns a Lamborghini, and a green plater chick that must be the daughter has a brand new 2 door merc lol
Anyways il see if in the near future I can find some better meet spots and mix it up a little.
So this Friday wooo
Looks like im in :D
For anyone going up from the South-East and don't wan't to appear foreveralone driving up to the meet point.
Some of us are planning to meet beforehand at:
7/11 Petrol Station [used to be Mobil]
Cnr of Springvale and Hawthorn Road.
Time: 9:15 to 9:25
Then will just drive up Springvale Road and hit the Eastern Freeway to drive up to Doncaster East.
:cheers:
So this Friday wooo
Hey James...you going to post up the map for people or you going to give it out on the night? skimmed through the thread and did see any mention about the map. You going to be using the one i sent you? or did you alter it?
Man if you could post it up for me that would be great, I'm on my mobile.
this is an old map brah...
used this last year i think twice...it was awesome....dw i driven those roads :P
if people like it enough...i might organize another one in mid December...
Looks like im in :D
Time: 9:15 to 9:25
:cheers:
I might be in for this :P. I live just down the road from Knox so I pass there anyway.
Only thing is might be grabbing some food with some mates beforehand so dunno if will be coming from this direction or not. Will confirm if I do :D.
Should be in for the cruise though. Yay first cruise. Worries about my ~half tank remaining. Maybe I should fill up :P
Yeah come to the meet point then fill up :P
Hey guys,
I've been eyeing this cruise for quite some time and I'll be turning up in the v35 sedan/maxima tomorrow evening. I'll probably be the slowest out of you boosted guys out there but it should be fun. I'll make a mention in the v35 forums of this cruise to see whether other V35's will be keen to come for a night into town. The only thing that is holding me back is that my car is still in the panel beaters getting a small crack fixed in the front bumper, but they gave me updates today and said that it will be ready tomorrow....I hope :)
Hey guys,
lol dont stress, it aint going to be a race, besides you wont be the slowest my brother is coming in his fiat 500 and a mate in a lexus
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
