  • Replies 160
Here are some photo's on the night
Whoever was in the red pulsar didn't know you were from SAU, and sorry was a lil late as had en emergancy to attend to :/
Pics include my car breaking down and having a chat to cops of which one used to be on SAU and drive a worked 33 GTR :D
I got more pics on FB but just a pain in the arse uploading individual pics, can PM if you want to see the FB photos.
haha it's just an example of an over capitalised daily :merli:
Though that said I didn't have 3 passengers, was much easier to corner easily with -180kg :D
The Racepace Tiens make all the different though I must say. Not cheap, but certainly perform the assigned task!
Had i realised you had 3 people in your car you could've just chucked on in mine man!
Yea the car feels so heavy and sluggish filling up for the first time....the 4 seater! haha
Never realised you had racepace built tiens..I was so tempted going down that path because I was gonna get modified upper arms made for my car from them.
James you mentioned your brother was coming in his Fiat, was it a red one?
I noticed driving up to King Lake that there was a Red Fiat 500 driving up then pulled over to the side of the road
yeah that was him lol, he said he was tired and decided to turn around and go home like the party pooper he is
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
