So you want more and more and more power, and a GTR style body kit .... why don't you just buy the right car = sell your Gtst and buy a GTR. It is the only real answer. As everyone has said above, you will continue spending significant amounts of money to get more power .... start on the right foot and just buy a GTR!oo
okay need genuine help, I have to replace my front bar, it has cracks in it mostly from the prev owner it is tooo low, it looks like 400R, anyways I have found a type M bar which is a few inchs smaller off the ground and looks neat but they want 300 for it including the lights! I am having a hard time finding a decent bar for my car under 500 bux its a s1 R33 coupe. cant be factory becoz of the FMIC.. what do you guys think of the type M bar
  • Replies 46
Posted Images
In future Mikey, please have the courtesy to reply whether you are interested in parts you inquire about.
Myself ( an i have helped you) an many are here to help answer questions you have or provide assistance with things, but please return the good deeds by indicating your intentions rather than ignoring those who help you :thumbsup:
I thought I had replied, currently i am still looking anyways havent made a final decision, sorry if i hadnt replied I have a few inboxes to look at, but I will let you know asap, your bar is alright but id need it to be resprayed for one. but I will get back to you, thanks again
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
