Hey guys need some knowledge here.
I want to run an external wastegate on my rb20det. I was originally and still want to weld it to my stock manifold but the position where I wanted to put it (on top of the manifold) the intake pipe gets in the way.so I thought how much to the right can I move over but it's too much that it's on a bend.
Is there anywhere else that I can weld it to the manifold that it won't b in the way of anything?
And does it matter where it's positioned for flow purposes?
Ur help is much appreciated
Thanks
Jason
https://www.sau.com.au/forums/topic/375795-external-wastegate/
i asked around a few places and none of them wanted to do the job due to it being cast iron and they can't guarantee the work or if it will even turn out properly.
who did the weld job for you JKR-32 and how much did it cost ya?
pm sent.
edit: looks good man, is that a steal pipe running of the manifold to suit a 38mm ext gate?
has anyone tried fitting a 40mm ext gate off the manifold or turbo housing?
My mechanic done the work mate. Not sure what diameter pipe actually. But its ha the old style turbo smart 45mm pro gate hanging off it. Brad does all my mechanical, fabrication and tuning. Handy bloke, but as is always the case with good mechanics, it's a jump in line type senario. Not sure on price, because he done the turbo swap, intake pipe, and dump pipe all at the same time as the gate. Along with a few other things.
Yer I dOnt really want to weld it to the exhaust housing just incase I need to changed turbo or something like that, that's y I want it on the manifold.but it's hat to find someone to do it as being said it's cast iron an all and ppl can't guarantee the welds.even though I'm sure if it's done the proper way an no shortcuts that it will hold. Does anyone know anyone in melbounre that will weld it??? Pref in northern suburbs???
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
