Item:
- R34 GTT HSD HR Coilovers - $800
No Leaks
No knocks
<10,000km since new
- R200 R34 Turbo Manual LSD Diff - $200
Good condition
Spins two
- R34 Coupe Sunroof - $800
Comes in roof section
Includes all wiring and sunroof switches
- R34 Coupe Doors Complete - $150 Each
Glass
Window motor
Central locking
Wiring loom
Hinges
- R34 Coupe Rear Quater Windows - $150 Each
Glass
Rubbers
In steel panel (cut with plasma)
- R34 Coupe GTT Manual Complete Interior - $Offers
Front Seats (airbags intact)
Rear Seat
Carpet
Front Door Trims
Rear Trims
Parcel Shelf
Roof Lining
Manual Centre Console
Dash (no cracks, airbags intact)
- R34 Front/Rear Control Arms - $60ea or $100/pair
Ball joint and bush in good condition
Comes with nut and split pin
- R34 Castor Rod - $30ea or $50/pair
Bush in good condition
Comes with nuts
- R34 GTT Swaybars (front and rear) - $100ea
Good upgrade for Non turbo S-chassis/R-chassis
- R34 GTT Rear Arms - $30ea or $100/set of 6
Toe, camber, traction
- Front knuckles - $100/pr
Good condition
- Front Reo - $50
Not bent
Cut for FMIC
- Front Fiberglass Widebody Guards - $100/pr
Passenger side mint
Drivers side previous fiberglass repair, refer pic
- R34 GTT Coupe 3" Dump Pipe & Full Exhaust - $300
Mild steel
De-cat
Comes with straight pipe and muffler rear sections (unbolts)
- R34 Carbon Fiber Bonnet BLITS ADR Approved - $50
Shit condition
Perfect for rough track car
- Bonnet Hinges - $50/pair
Good condition
AC Condenser - $50
Excellent condition
Comes with all pipe work
R34 Power Steering Rack - $250
Complete with tie rods and tie rod ends
Rubber boots in good condition
Location:Melbourne, Cheap Freight AUSWIDE with www.e-go.com.au
Item Condition: Was was in good condition inside and out
Reason for Selling: Stripping out entire 34 Coupe
Price and Payment Conditions: Cash
Extra Info: Have plenty more parts available, ask and you shall receive
Pictures:Available
Contact Details:PM
PARTS SOLD:
- Engine/loom/ecu
- Gearbox/clutch/crossmember/tailshaft/etc
- Bare rear cradle
- FMIC
- Alloy Rad
- Complete brakes (disks/calipers/lines)
  • 3 weeks later...
  • Replies 53
Item:
No Leaks
No knocks
<10,000km since new
Do you still have the bottom plastic diffuser ???
Good condition
Spins two
Glass
Window motor
Central locking
Wiring loom
Hinges
Glass
Rubbers
Rear Seat
Carpet
Front Door Trims
Rear Trims
Parcel Shelf
Roof Lining
Comes with nuts
Good condition
- Front Reo - $50
Not bent
Cut for FMIC
Passenger side mint
Mild steel
De-cat
Shit condition
Good condition
AC Condenser - $50
Excellent condition
Pictures:Available
Contact Details:PM
PARTS SOLD:
- Engine/loom/ecu
- Bare rear cradle
- FMIC
- Alloy Rad
is the car complianced and is it a stat write off
and how much for bare shell plus whatever is left over yuou can't sell. prefer to get with sun roof as this would be a c*nt to get
in melb
Do you have the little white plastic lid off the fuel tank? The one with the hoses and fuel pump wires going through it? If so please PM me a price. I am OS at the moment so it might be a little while before I reply.
Ta
Justin
did you have fiberglass front fenders still ?photos ?
floor mats ?
drivers side a pillar trim without broken pins or holes?
little triangles near a pillars on doors to hide screws on mirrors ?
drivers side seat belt if its not frayed
both sides seat belt , push button click in parts on the seat frames ?
door panels ? front and rear sides ? with trims/plastic handles. and the trim around switches ?
window switches ?
the little trim around the sunroof switch on the roof in front ?
rubber between the mirror and the windscreen to stop vibrations ?
drivers side reverese lens if its in good nick
