Wrecking 2000 R34 Gtt
Item:
- R34 GTT HSD HR Coilovers - $800
No Leaks
No knocks
<10,000km since new
- R200 R34 Turbo Manual LSD Diff - $200
Good condition
Spins two
- R34 Coupe Sunroof - $800
Comes in roof section
Includes all wiring and sunroof switches
- R34 Coupe Doors Complete - $150 Each
Glass
Window motor
Central locking
Wiring loom
Hinges
- R34 Coupe Rear Quater Windows - $150 Each
Glass
Rubbers
In steel panel (cut with plasma)
- R34 Coupe GTT Manual Complete Interior - $Offers
Front Seats (airbags intact)
Rear Seat
Carpet
Front Door Trims
Rear Trims
Parcel Shelf
Roof Lining
Manual Centre Console
Dash (no cracks, airbags intact)
- R34 Front/Rear Control Arms - $60ea or $100/pair
Ball joint and bush in good condition
Comes with nut and split pin
- R34 Castor Rod - $30ea or $50/pair
Bush in good condition
Comes with nuts
- R34 GTT Swaybars (front and rear) - $100ea
Good upgrade for Non turbo S-chassis/R-chassis
- R34 GTT Rear Arms - $30ea or $100/set of 6
Toe, camber, traction
- Front knuckles - $100/pr
Good condition
- Front Reo - $50
Not bent
Cut for FMIC
- Front Fiberglass Widebody Guards - $100/pr
Passenger side mint
Drivers side previous fiberglass repair, refer pic
- R34 GTT Coupe 3" Dump Pipe & Full Exhaust - $300
Mild steel
De-cat
Comes with straight pipe and muffler rear sections (unbolts)
- R34 Carbon Fiber Bonnet BLITS ADR Approved - $50
Shit condition
Perfect for rough track car
- Bonnet Hinges - $50/pair
Good condition
AC Condenser - $50
Excellent condition
Comes with all pipe work
R34 Power Steering Rack - $250
Complete with tie rods and tie rod ends
Rubber boots in good condition
Location:Melbourne, Cheap Freight AUSWIDE with www.e-go.com.au
Item Condition: Was was in good condition inside and out
Reason for Selling: Stripping out entire 34 Coupe
Price and Payment Conditions: Cash
Extra Info: Have plenty more parts available, ask and you shall receive
Pictures:Available
Contact Details:PM
PARTS SOLD:
- Engine/loom/ecu
- Gearbox/clutch/crossmember/tailshaft/etc
- Bare rear cradle
- FMIC
- Alloy Rad
- Complete brakes (disks/calipers/lines)
  • 3 weeks later...
  • Replies 53
Item:
No Leaks
No knocks
<10,000km since new
Do you still have the bottom plastic diffuser ???
Good condition
Spins two
Glass
Window motor
Central locking
Wiring loom
Hinges
Glass
Rubbers
Rear Seat
Carpet
Front Door Trims
Rear Trims
Parcel Shelf
Roof Lining
Comes with nuts
Good condition
- Front Reo - $50
Not bent
Cut for FMIC
Passenger side mint
Mild steel
De-cat
Shit condition
Good condition
AC Condenser - $50
Excellent condition
Pictures:Available
Contact Details:PM
PARTS SOLD:
- Engine/loom/ecu
- Bare rear cradle
- FMIC
- Alloy Rad
did you have fiberglass front fenders still ?photos ?
floor mats ?
drivers side a pillar trim without broken pins or holes?
little triangles near a pillars on doors to hide screws on mirrors ?
drivers side seat belt if its not frayed
both sides seat belt , push button click in parts on the seat frames ?
door panels ? front and rear sides ? with trims/plastic handles. and the trim around switches ?
window switches ?
the little trim around the sunroof switch on the roof in front ?
rubber between the mirror and the windscreen to stop vibrations ?
drivers side reverese lens if its in good nick
 Share
    • There are two. One with "intelligent key" (proximity key) and one without. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/pm35/6844-vq35de/body/998 Doesn't look like a shared item outside of V35 Skylines which may be handy if looking for a wreck. https://www.amayama.com/en/part/nissan/d8700cg027 https://www.amayama.com/en/part/nissan/d8700ac228
    • G35x should be a match. Not sure if the 2008+ items will be a direct fit as they might need the front axles also - much like when upgrading to 370z rear bearings, but the 2004+ should since they are the same chassis as our PNM35 Stagea. For what it's worth, I used replacement bearings from JustJap last year which need to be pressed onto the hub.
    • Point 1. If you want to do this and want to use that engine, just buy the whole Stagea. You will hate yourself less by getting everything on it all at once and then having to dispose of the stuff you don't want, compared to how much you will hate yourself if you miss buying something and it isn't there when you need it. If you can't afford to buy the whole wreck, then you can't afford to do the swap anyway. 1996 Stagea does NOT have a Neo. It is a version of the vanilla RB25. There is a bit of a halfway-house RB25 that was in Stageas at that time that kinda look like a Neo, in that they look like they have some Neo looking parts on them. But they are not Neo. They have hydraulic lifters and the same old bottom end as the vanilla 25. So, technically, putting that engine and its ECU into an R34 might be challenging. There might be some shenanigans with ABS communication, for example. I'm only guessing, because I've never contemplated messing around with stuff from that era. Sadly, you probably cannot Nistune the ECU (I haven't checked, but R33 era RB25s don't have a Nistune option because they have a stupid orphan ECU). So you will possibly end up contemplating an aftermarket ECU to get it working. You will DEFINiTELY want to take the Stagea's auto trans. The one in your car will die in very short order, especially if you turn the boost up at all. This is true even if you add a turbo to your existing stuff. Hence why I suggest buying the whole wreck.
    • Hey @sycotixwhere did you get the spark plugs replaced?  was that somewhere in Hoppers crossing too?   I’m planning to go to Backlash Automotive in Hoppers when my clovers come but if you found a decent garage on this side to do spark plugs, I’d be interested too.    PS: also been reading the drama with the car at the start. Glad you got that sorted
    • I thought you were remarkably coherent and made the most of the inane questions you were given to work with. I love the thumbnail shot with dust blowing up from the diffuser.
