hey guys im new to SAU, i have done a fair amount of searching on the forums, as i am looking for a list of part numbers for my 1998 er34 running an rb25det neo.
everything under the hood is stock, except the exhaust, its in dire need of its 100 thou service, and im busy rounding up parts, i also need to know the best oil for engine, trans, diff, best coolant to use. bearing in mind this car is only for street use at this point in time, i would still like to spend that little extra to make sure she runs sweet. here's what ive got so far:
1.air filter = RYCO A360
2.fuel filter = RYCO Z200
3.oil filter = RYCO Z145A
4.engine oil = CASTROL edge 0w40
5.sparkplugs = NGK PFRGG-11, or iridium BKR6EIX-11
6.timing belt = BOSCH BT1040H
are these good choices? if not, can you list a better one, and also, part numbers/names i dont have yet are:
7.tensioner pulley =
8.idler pulley =
9.air con belt =
10.power steering belt =
11.brake pads =
12.clutch fluid =
13.brake fluid =
14.coolant =
15.thermostat =
16.oxygen sensor =
17.water pump =
18.injectors (stock?) =
19.coil packs =
im sure there is many more parts that need the occasional replace, but im new to imports and skylines in particular, and by new i mean a total noob :P any help would be greatly appreciated, the more recommendations the better, as it will help build a solid list of parts for this model.
I am more then happy to help people on this forum identify and replace any lighting bulbs, both exterior and interior in the r34, as i have done a complete refit of every bulb in the car, and i can also detail any particulars and diy to help you install custom bulbs yourself, even with a few pictures included.
cheers lads, ladies, and haters:D
https://www.sau.com.au/forums/topic/375809-anyone-got-part-numbers-for-er34-98/
i've heard Ferodo brake pads are pretty good, but i've already purchased a set of Bendix pads for my service.
coolant that my tuner uses for my r34 is calibre long life coolant (anti-freeze/anti-boil) 20bux at supercheap.
you should have a look at the kudos website they are sau trader, you will find genuine nissan parts and aftermarket stuff including part numbers.
http://www.kudosmotorsports.com/catalog/nissan-skyline-r34-25gtt-c-21_22_28.html
cheers
contrary to popular belief and despite all their marketing, Castrol oil is not actually that good. It's too thin for Australian summers and doesn't offer the same protection and temperature stability as the other synthetic oils.
Of the common brands, Penrite, Mobil or Motul IMO. anything from 0w to 15w depending on kms.
I work at repco, ill have a look on monday for some part numbers for ya ;)
http://www.kudosmoto...c-21_22_28.html
cheers
Ferrodo pads are shite. A budget option at best. I've heard of pads on a Territory last less than 12,000 kms (normal driving). Unless you get thermo quiets, they're a lot better. Bendix CT pads still take the cake for affordable pads.
you should be able to buy the bosch timing belt and pullies as a kit
platinum/iridium plugs are massive waste of money, get some copper plugs like a BCPR6E
as above Castrol oil isn't what is commonly used by most skylines owners that have a clue, got for the gold mobil 1 or motul 8100 xcess
why would you replace your fuel injectors? at best get them cleaned and flow tested
are yu having issues with your coilpacks ie. missing? because if not then you don't need to replace your coilpacks either.
so Mobil 0w40 is the way to go then? when i purchased the car it came with a 5litre of castrol 0w40 in the boot, so i assumed twas' decent, ill look into chaning it, should i flush the oil out with a random crappy oil before changing to mobil? work at repco? LEGEND!
cheers for the help
1 of the 34's is having a strange uneven idle, not really bad, just sound unusual, was suggested somewhere it was probably my coilpacks on the way out( have no idea how to test them:S). injectors would be something ill be needing to change in the near future on the other 34, i have no idea why, as my mechanic didnt specify, but ill be sure to double check with him what the deal is on injectors.
do you happen to know if you can get the pulleys as a seperate item to match the belt? i already have the belt, found it in the boot with some castrol oil :D, i doublechecked it to make sure it was the right one, apparently previous owner was getting ready for 100thou service, but decided to sell due to financial difficulty, poor bugger. cheers for the help
Get genuine timingbelt and tensioners from nissan dealership - their prices are not so bad for these items.
Probably a good time to get a new waterpump too.
Brake pads - go genuine too - but it is on the pricey side.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
