So his definition of a boat is a car that doesn't appear to "go" and looks overly heavy and unable to pull off of it's own weight.
R33 GTS N/A '93 RB25DE
*He has not been in my car nor seen it take off.
So I was just asking your opinion on this, is my car really a fkn yacht or is he just talking crap because he still drives his mummy's camry?
One other thing, I have a blazt ecu cable and every time I plug it into any of the 3 laptops I have the USB is never detected (All different OS's and Admins) but when I plug it into my PC it detects and installs.
Thanks guys
https://www.sau.com.au/forums/topic/375815-friend-claims-my-r33-is-a-boat/
  • Replies 71
Posted Images
Check legacy usb is enabled in bios of laptops?
Secondly, skyline>camry, however yes its a boat as it is slow and if stock suspension then high with alot of body roll....
What do you care what your mate thinks anyway.
with the RB25DE your in the same league as Lexus XE10, BMW E46 Inline 6....these are cars that are just used for smooth Cruising and to look good while doing it, and there is no point of thrashing the nuts of them because they are not meant to be Performance Cars. If you start comparing it to Turbo Skyline then YES its a Boat, but put it in it league and it does well.
Lol not even in the same ball park as the M54 engines.
Not to mention any E46 325/330 would smoke a GTS Skyline given that they do 0-100 in under 7.5s (330 does it in 6.5).
Who cares,they are not even worth Racing or going fast in they are both slow.
Last time I checked 6.5 seconds is pretty good for a NA 6 cylinder in a luxury vehicle. Given that your RB25DE would do 8-10...
My point was the M54 BMW straight 6 is a fantastic engine with good engineering and should not be classed as being in the same league as a RB25DE.
Rather an RB though these guys from NZ claim to be Abusing there $700 R32, RB25DE for a solid 4 years and its still not letting up, though they Break like 50 Laws in this video, Maybe Underpowering the RB25DE was a move by NIssan to add Durability to a Engine you would not get with a Turbo.
They are slow. Turbo skylines which are stock as a rock are also quite slow but still not bad for a small turbo motor. There aren't much for the price you can get which are quicker. A slightly boosted turbo skyline with the basic mods(exhaust and probably cooler) is faster than a BMW M3. I had about 180rwkw when I was stock and I managed to get ahead and infront of the M3 bmw V8. Just enjoy the car.
When you are able to get a turbo, you will love it. A skyline with greater than or equal to 200rwkw is a very fun, nice, powerful and fast car.
Love the video above, not many 2.0NA motors can do that!
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
