I think you were apart of the original discussion about Multi vs Single throttles when i googled some old threads on SAU. The car isnt a circuit car and its main purpose is being a street car. And setup for straight line performance. Because of this i always assumed Single > Multi. I also found this while going through old threads.
I am also building a Rb30/26. I have asked Nathan from HiOctane which Hyper tune Plenum would suit....here is the correspondence
Hi Matt,
It depends what you are using the car for. If you are using it for street use then yes they are good(6throttle Hypertune). However if you are just going for outright power then you are better off with a single throttle plenum.
What size did you need those pistons in?
Regards,
Nathan Welland
Sales And Marketing
I use the car for street and track days, The drag strip in Adelaide is closed :blink:
I am a firm believer in achieving maximum average power and torque.
What gains will the 6 throttle plenum achieve at my target power/Flow?
Matt
Hey Matt,
The plenum itself does make more power than the standard one. Once you reach over 400kw atw it is no longer the plenum that becomes the restriction it is the throttle bodies. The 6 throttle is better for over all response not maximum power figures.
Regards,
Nathan Welland
Sales And Marketing
Hmmmmn, That's hard to believe since the combined area of the 6 butterflies minus the shaft is still more than the single TB. I guess the extra turbulence caused at the inlet causes the issue.
So you would say.
6 TB Plenum for GT-SS, 2530, GT2860R-5
Single TB Plenum for Big Singles
I guess I'm right on the line.......I think the 3ltr will give pretty decent response so very hard to say which will make more average power....
hmmmn
Matt
Oh sorry I didn't realise you are running a 3L ( now that I look back over the emails I see you did say 30/26 ) On a 3L the multi throttle is not worth it single all the way. We are using a single on our new R34 race car which is a 3L.
Regards,
Nathan Welland
Sales And Marketing
We did pressure test the throttles and there was some hissing around the throttle bodies. We couldnt determine exactly if it was the bearings or the actual flaps but since it was out we decided to clean everything up and replace the bearing seals as well.
  • 4 weeks later...
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
