hey guys, found a few bits when cleaning!
stok dr30 seats, 1 is in good nik other needs to be retrimmed cos my dog got at em, has rails still so can seperate if u wanted to fit up aftermarket seats $50.00
have about 6 r30 lcas some in good nik sum ok the lot 4 $50 or $5 4 ok 1s $10 4 good
also have stok castor arms $40
fj 20 inlet manifold $50
if u need ne thing let me no,
0419469108
can throu a few pics up if needed its all stok stuff so im sure u guys no wat they look like
as always everything neg.
cheers,
https://www.sau.com.au/forums/topic/375818-fj-inlet-mani-r30-bits/
You guys have to be kidding yourself?
These parts are near impossible to get and your saying "probs abit pricy 4 me" ???
How much is too much when it isn't procurable????
A wrecker if they had one would be $100.00 minimum, so I guess you want it for FREEEEEEEEEE !!!!!!!!!!!!!!!!!!
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
