hey all,
so I recently purchased a 1995 S14 series 1, with a series 2 front and rear end conversion.
perfectly running sr20det and running an s15 6 speed. however you can have the choice of a 5 or 6 speed with an adjustment to the price. (both gearboxes in perfect cond.)
currently the car is un-registered and un-roadworthy. my reason for selling is because the previous owner neglected to mention the car was a repairable write-off and hadn't had a VIV reported to vicroads. also has an EPA on the shell too.
so I handed over the cash without checking with Vicroads thinking I could just fix it and get a RWC then drive it like what I was told.
the car is dark blue - originally red. would suit someone who has a bigger budget than me or looking for a cheap s14 for track use!
COMPLETELY STOCK car.
price:
$4400 with the s14 5 speed (you will have to swap the box)
$4600 with the s15 6 speed
add $500 to cost with CST base height coilovers 8kg front 6kg rear in good cond.
will MMS pictures if requested, but its basically its a dark blue s14a with black s14 stock wheels.
contact Leigh on 0418-221-075
https://www.sau.com.au/forums/topic/375834-s14a-4500/
  • 3 weeks later...
    • Tbh, I have no idea who this is bahahaha. hint? I live in the real world now, certainly not swinging spanners anymore though
    • Joey, are you still in playing "spanner club" Mafia somewhere mate? Or you now out in the real world where you actually have to work for a living? BTW, the car looks clean, and the pods look sweet, are you removing to go full OEM type of resto?
    • I like the idea of tagging the model, and if GTS-t/GTt or GTR, and then a what, so wiring, engine, suspension.   That way you end up with a matrix, all content R33 GTST, or you can find all content that is wiring related for example.
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
