Hi guys i know this has been talked about on here before but needed some specific questions answered.
im looking at buying a r33gtst s2 with (as far as i know stock internals).
i arranged for a mechanic to compression test the motor with the results
CYL1 150PSI
CYL2 150
CYL3 140
CYL4 145
CYL5 150
CYL6 145
I wasnt actually able to be there when it was performed (work commitments) but when i asked if the test had been done cold or hot, the mechanic said cold
and that this was normal to do it cold and that the motors compression was fine.
having looked on here i can see most guys say to do it hot...
so my questions are
1. will the compression likely be higher when tested hot.
2. if tested cold can this hide potential problems with the motor.
3. what is an acceptable tolerance between cylinders (have seen conflicting info).
thanks for any info provide
Regards Will
https://www.sau.com.au/forums/topic/375899-rb25-det-compression-results/
With compression tests consistency between cylinders is usually more important than outright numbers, unless they're something ridiculous 90 on all cylinders. From the results you've given, it looks like a healthy RB25 :)
i wouldn't settle for "if its within 5-10psi of each other then its good"
id want minimum 160psi for each cylinder hot or warm, 140-150 is like 8:1compression ratio so lazy and worn out a bit... why settle unless thats what you have and have to work with it..
mine is 160 000kms old and still has 170+/-5psi, so a perfect condition motor is probably about 180psi each cylinder, i stand to be corrected.
less than 10 percent is a good result and afaik hot results usually give better compression
Is that between the highest & lowest reading cyl or when compared to the average/majority reading?
I got one at 155 (cyl 1), one at 165 (cyl 5), rest all @ 160
  • 7 months later...
