Classic 1 Day Rally 11Th Sept
<br />I think Bart (Dsturbd) may be.<br /><br />I entered last year with the wife, and we beat Brad and his wife (only just)<br /><br />Details can be found here in case people are interested:<br /><a href='http://www.classicrally.com.au/shannons_1_day_classic.htm' class='bbc_url' title='External link' rel='nofollow external'>http://www.classicra...day_classic.htm</a><br />
<br /><br /><br />\
last year I stepping as co-driver with my bro, about half way through,(his co-driver felt sick) in the white malloo, if you were in the 350z, looks like we beat you, I did the year before in the GTR.. good days, but pricey for seat time.
good luck OP
Yes, you beat us by a couple positions, but me and the wife shared the drive 50/50, seeing as its her car :)
<br />Yes, you beat us by a couple positions, but me and the wife shared the drive 50/50, seeing as its her car <img src='http://www.skylinesaustralia.com/forums/public/style_emoticons/default/smile.gif' class='bbc_emoticon' alt=':)' /><br />
<br /><br /><br />
ok well you two did good then.. bro goes pretty hard in the malloo ( tank )
which GTR were you in the 32 or 33?
i was in the red evo. was a good day and very nice weather
I was in the 33 whale
What's that on your left skirt?
Is it a mount for a camera?
Edited by R34
Regular co driver is overseas on holiday and my back up co driver couldnt do it due to his mrs due to give birth . Be back for the fabcar 1 day in December :thumbsup:
Tyson and his dad were 14th outright with 20 seconds worth of penalties >_<
Thanks Paul
I was a bit disappointed actually.
I didn't want to beat up my garage queen though(std clutch still lives :thumbsup: ).
It was fun but it would be great to build something light and RWD that I didn't care about.
Thinking cap is on about a "cheap" track car
Thanks Paul
Haha, cars were meant to be beaten up, then you fix the things that fail :thumbsup:
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
