I've got an R33 GTS-25T engine fan but the clutch hub keeps seizing on me. I've swapped it out for another one and after a few months the thing dies and locks again so the fan is on full blast 24/7.......... sounds like an old commo lol. I'm sick of changing it and wanted to get a new one from ni$an but they want ~$500. No thanks! Does anybody know where I can get an aftermarket replacement? It looks like this:
most people just keep changing them for second hand ones that are going cheap. so keep running wiht that until you get a good one unless u want to lash the $
otherwise if you arent too bad with wiring you can set-up a thermofan. Free's up kw and responsiveness. prob about 100-200 for a brand new thermofan setup + temp swtich etc
I did it, i love it. It runs cooler too...
  • 5 weeks later...
I bought one for my rb20det locally at auto parts store. Didnt cost that much from memory, like $100? It is the same as one off a local delivered car, like the maxima or vl one or something as well...
Are you able to be more specific on which local delivered car has the same clutch assembley?
Also are the clutch assembleys the same throughout rb20,25,26,30? The clutch in my 32gtr siezed this arvo and not sure if the local bursons will have anything if i ask for anything to do with gtr or rb26.
It only took about a month of going back and forth a million times to various places to finally get one that fits. None of them were in stock so you would have to go in, order it, pay a deposit, and then go back to get it, find out it doesn't fit, return it, get a refund and try again. Don't forget all the times of taking the fan off to do the install and then finding out it's the wrong one.
I ended up trying out 4 different fan clutches, all different manufacturers, all in different shops, all specifying they fit Skyline R33 GTS-25T / RB25DET / 2.5L / TURBO. Prices were around $100 but it doesn't matter because it turns out that the one that fits is DAVIS CRAIG for around $200. Save your headaches and a million trips and get it.
Anyways here's how the rest of them didn't fit - the holes wouldn't line up with the bolts, all were much worse than this pic in that the bolt centre's would be in line with the edge of the flange, so you couldn't even enlarge the hole to make it fit:
And as you can expect, this is what the Davis Craig one looks like - lining up perfectly:
I think it needs some breaking in because when I head off for work on cold starts the fan is on full blast, but after a little while it loosens up and then it's fine. Good luck with your fan clutches and hope that they don't seize on you :)
Edited by _Wing_
So it was just a Davis Craig viscous clutch for a r33? Anymore details on product code/number?
Cheers.
Fella's got the same issue. Except with an R33 GTR. Got a hold of davies craig and they have no idea for RB26DETT. The closest I got was Just Jap in Sydney had new ones but only for R32 GTR. I have lined up a 2nd hand replacement but would rather not have to look for one again in 6 months if it lets go also. Any hot tips?
Cheers.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
