dont be weak, get some real calipers that take 30mm thick pads! only have to change them once every year or so.. with track use.. and if a common racing caliper pads can be had pre bedded for less than 150 a set.
  • Replies 55
Posted Images
you tried these guys for DS2500s DJR? http://www.zeckhausen.com/Brembo/GT1_Pads.htm
pad choice for F40/F50s is probably second to none. all the euro stuff is available, so is the US stuff and even the japanese stuff is all made in F40/F50 pad shapes.
as far as the cool kids go, they most often mistake my F50s with 355mm rotors for stock R33 brembos... lol definitely no cred, especially since they fit under my 17inch LMGT4s...
From zeckhausen
The 16mm FDSR3028 w/o sensor slot is no longer available in the USA and possibly Europe, but the 16mm thick version with the sensor slot is available. I'm checking to see if it's sitting in the USA or if it has to be ordered from Italy.
Meanwhile, I've added the 16mm thick pads to our part numbering system with a "-1" extension to differentiate from the 18mm thick pads. See: http://store.zeckhausen.com/catalog/index.php?cPath=82_85
Will let you know about availability shortly.
For some reason, the thinner 16mm DS2500 is more expensive than the 18mm version, however the pricing is reversed with the DS3000, with the 16mm version being cheaper. Odd.
Then:
I just heard back from Essex - the importer of Ferodo into the USA. They state the FDSR3028H is not available and they do not stock the FRP3028H. It would have to be special ordered from Italy with a lead time of about 8 weeks.
I think I'm going to buy a set of the project MU titan HC for my F50s. yes they are 18mm but they list them as suitable for front calipers. maybe F40 to F40 is slightly different width? for $179USD I think they are pretty keenly priced.
Well let us know how you get on. Are they a new pad because I cant remember Project Mu doing something with that working temperature range. Local price is $444. Ow.
I think I will order the 16mm pads (and wait a bit) then check them with a 2mm spacer.
fk me dead. $444 is harsh. I thought $178 was cheap but was thinking more like $300-$350 retail. :( will let you know. if it comes to it I'll need to spend some time grinding the bastards down... :(
yes. 400 for little 16mm pads is horific. just think, 2 pad changes and youve almost bought a set of forged monoblock race calipers with titanium pistons.. fyi using evo pads in the f40/50 caliper lowers/widends the contact area buy about 10mm. but they are thinner.
Have you tried PFC06? They are a nice bitey pad, but in my car I struggle with locking brakes with them. I am abotu to bin them for some RS4-2. Much lower bite nad friction coefficient. I think some of the high u pads are for non boosted brakes etc
  • 9 months later...
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
