Have a guy who is really keen but wont be coming to look at it for a month due to work commitments interstate.
@effectx Loans are pretty easy to get these days :thumbsup::whistling:
  • Replies 96
Haha, fresh battery just put in :thumbsup: Stock airbox has been put back on (as the pod didnt seem to do anything). Also just put in some White Led parkers, look the goods :banana:
Manual conversions arnt too expensive :whistling: One was on ebay recently for 500, full kit, box, pedals the works. If I had the money I would have bought it but since I am currently going to Uni I no longer have money to put into this car.
mate the reason this hasnt sold yet is because
1. its AUTO
2. NON turbo
3. 4 door
3 reasons most beople DO NOT buy and import, you have a rare few who want that but mate you may aswell keep yor car because the only people who will pay 7k for a 4 door non turbo auto are brain dead mules
these sell for 3-4 k now
your never going to get 7k for it, just keep it and in 2 years turbo it chuck a 5 speed in it, and you'll love it then
btw i couldnt sell my 2 door turbo with 12k in parts in it for 8k,a
Ive had offers of 5500, the fact its N/a opens it up for p-platers who dont want a little buzz box but dont want a falcodoor.
4 door just means less hastle of getting people in and out of it (as a teenager your gana have alot of people getting in and out).
The auto is the main issue everyone seems to have with it. If i had the money and time id convert it to a 5 speed but i am strapped for funds and time going to uni.
Also these days alot of teenagers dont seem to get there manual license as most parents seem to be going for new cars that are auto as a family daily. So really its a good car for the market, or as you put it rare few, that it will appeal to.
I guess its each to there own as to what people think its worth, im just putting on what id be happy to let it go for and think its worth. There isnt too many P-plate legal 32's around and I am always getting complements on it.
It is a nice example you are correct!
However it's been for sale for six months?
I assure you if it was worth it it would have sold, it just looks like the price of skylines has dropped again with 33GTR's selling for under 20k now
I ended up keeping my 32, it just wasn't worth giving away to me. And you are most def right about the manual bit, just change it bro
300 for a box, couple hundred for ecu and manual bits, some elbow grease and it will sell
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
