mandrel bent 2.5" mild steel custom made system. include 0-2 extra mufflers in the middle of the system, oval muffler on end.
will cost around 600 or so. just go to a local exhaust shop and get one made up.
this topic was covered in a previous post .... MANY times, in fact there was one just yesterday if you had bothered to read.
There is five different threads about exhaust systems for non turbo skylines on the first page of this section.
They need to put a sticky or something in huge bold writing because every single retard comes into this section of SAU and asks the same question.
gain performance through exhost?
easy mate, just make the piping as big as possible, 2.5" has been suggested cos its just too expensive to buy enough metal to make 5" piping. bigger piping = tons of air flying right through.
also sticking a whopping great big cannon will make your cars exhaust system be just as powerful as what the name suggests - A CANNON
your skyline will now fly
okay il be serious now, exhaust isnt a very great way to make more power. in fact anything n/a isnt a very good way to make more power.
this is why you are advised to SEARCH.
in fact, had you searched, you would also have found out that extractors are nastily expensive for the relatively little power they give unless you like to be in mid-high rpm ranges, and even then its still nothing special.
and if you at least did not say "cbf searching" - you would have at least avoided my sarcasm.
im picking up a nismo 2.5" cat back tonight. ill fit it tomorrow and tell you guys how the car feels.
im guessing it should be pretty good since it is a genuine nismo item for an NA
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
