Some have reported good results some havn't.
:D
I've decided to do the mod again since I am running a bit more boost up in the higher rpm's due to my bodgy wastegate mod that reduces the wastegate travel. I'll let you all know if it makes boost in the higher rpms as previously the way the wastegate was setup it would hold boost perfectly.
Theoretically it should creep boost the higher the rpm's go IF the re-circ leak was causing some boost drop. This is only the case with the way I have setup my wastegate hence reduced travel so boost is forced to be made.
I recessed the hole a little so the top of the screw would sit flat. As not to accidentally lift the bov on one side hence leaking out the side of the gasket.
The screw I used was a good ol' short stubby computer case fan screw.
While I was there I checked the piping to see how coated with oil it was.
Suprisingly after 160,000km's (90,000km's of hard 1bar+ boosting, currently 1.1bar 16-17psi) its all pretty clean. Slight bit of oil on the bov its self however the piping is rahter clean. Well compared to 95% of the other R32's I have seen.
https://www.sau.com.au/forums/topic/37606-stock-bov-leak-fix-mod-pics/
I have noticed the following since the mod:
1. Boost is definately much much quieter. Similiar to a car that has a stock airbox.
2. Appears to feel like it has a little more guts down low.
3. Boost appears to be a little lethargic when first starting to make boost - this could be due to not hearing the psssssshhhh as boost comes up.
4. This mod only appears to be of benifit when running 15+ psi.
5. Boost does creep up like I thought.
6. Constantly hits boost cut now :) Time to fiddle again.
7. Changing from first to second when accelerating moderately some times is a little rough.
Think thats it.....
How are the aftermarket re-circ bov's setup? Do they have this recirc bleed type hole?
I don't think they have Joel, well the TurboSmart one that a mate has got hasn't.
I've always wondered if a aftermarket plumb back would give the same feeling as this BOV mod does....
J
It definately does hold boost easier up top now.
I've had to back the boost off so it doesn't boost cut.
I didn't notice any difference at the lower boost levels though (13psi @7000rpm) as it would hold 13psi at 7000rpm easily anyway.
The problem began when I started to try and hold 1bar+ up to 7000rpm.
As I said previously I elongated the wastegate holes in order to reduce the travel of the wastegate hence forcing it to hold boost. So obviously there is a little to be had by stopping the constant re-circ with the stock bov.
Yer the RB20t wastegate is a tougher wastegate (stronger spring).
When I had the VG30BB wastegate on it she would drop boost to around 9-10psi like yours.
The RB20T stocker wastegate with exhaust is 10.9psi. Well mine is anyway. :)
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
