  • Replies 129
few V35's meeting up at mc donald's in springwood at 8.15
Also will be attending and cruising up from the gold coast-not sure where maccas is in spring wood but keen to cruise up in a group, ill be heading off from upper coomera, can we set a concrete time and provide addresses??
im keen to meet up wit u guys at spring wood maccas.. but i may have to go to auchenflour to pick up a mate whos keen to tag along wit me
I will be travelling that way. Surely there is a closer meet up point than springwood
Anybody keen for a Indro Coles carpark meetup on the morning?
hey maccas in springwood is just off the highway, so its easy access to and from the highway, search for cnr of springwood road and rochedale road in google maps to spot mc donalds, springwood.. meet up time is 8.15 and depart at 8.30 to aspley
Edited by shiva
donation ($10 ) will net you a sticker and from there the ability to do the parade lap. strongly suggest buying raffle tickets as well all of htis goes to the cancer council.
expected to be a big day with 100+ attending.
Hey miso,
If you keep to drive to aspley together give me a buzz. Otherwise will drive up with just Dion (Asked him, but he hasn't got back to me yet)...
There only seems to be us 3 from the forest lake area :(
Edited by wilorichie
Hey miso,
Hi Richie,
Do you wanna stop by and join the group at springwood mc donalds at 8.00am. Few V35's meeting up there.....
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
