  • Replies 129
few V35's meeting up at mc donald's in springwood at 8.15
Also will be attending and cruising up from the gold coast-not sure where maccas is in spring wood but keen to cruise up in a group, ill be heading off from upper coomera, can we set a concrete time and provide addresses??
im keen to meet up wit u guys at spring wood maccas.. but i may have to go to auchenflour to pick up a mate whos keen to tag along wit me
I will be travelling that way. Surely there is a closer meet up point than springwood
Anybody keen for a Indro Coles carpark meetup on the morning?
hey maccas in springwood is just off the highway, so its easy access to and from the highway, search for cnr of springwood road and rochedale road in google maps to spot mc donalds, springwood.. meet up time is 8.15 and depart at 8.30 to aspley
Edited by shiva
donation ($10 ) will net you a sticker and from there the ability to do the parade lap. strongly suggest buying raffle tickets as well all of htis goes to the cancer council.
expected to be a big day with 100+ attending.
Hey miso,
If you keep to drive to aspley together give me a buzz. Otherwise will drive up with just Dion (Asked him, but he hasn't got back to me yet)...
There only seems to be us 3 from the forest lake area :(
Edited by wilorichie
Hey miso,
Hi Richie,
Do you wanna stop by and join the group at springwood mc donalds at 8.00am. Few V35's meeting up there.....
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
