  • Replies 551
Posted Images
Aww i thought they might have those Rodeo bull robot thingys, probably not something u would want to jump on after a big juicy steak anyway :P
Great post N1, made me want to start driving down there already, not sure if my hotel has a pool though, Mr Moo went and organised it all!
Are you all insane?
You get to Shepp ASAP on the day, and the only stop thats needed, other than minimal petrol stops is for THE DRIVE THROUGH BOTTLE SHOP 1KM FROM THE MOTEL!!!!!!!!! Check in early as can be, get the booze in the fridge, board shorts on, get in the pool with booze - FKN WIN!!!! Then, when you're sick of that, you go up the street towards Taco Baz's and then RIDE THE COWS!!!!!!!!!
Geeeeez!
I'm with Steveo, It's already a 7hr drive. toilet breaks and petrol only.
I should only have to fill up once :P
Ok guys just been informed to stay out of Wang. The races and a jazz festival is on that weekend so it's going to be packed with drunk tards and crawling with cops. If u need fuel best places would be Benalla, Albury, or Shep.
Also just go easy when going through Wang seems like they are cracking down. Brother in law just got stickered the other week with his stockish supra.
Very sad realy,nsw has some realy good drivers,come on peeps.Gee if i had to do the track day i would be set on fire,me old and slow.But if there are only 4 nsw peeps i might have to put my name in,hey liz can you teach an ol girl new tricks. :action-smiley-069:
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
