Wtb: R34 Gtt Airbag Or Steering Wheel
Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
By R32withaLS · Posted
Any updates I got same drama? -
I had my car model wrong on my Shannons insurance when i had my V36. didn't make a difference when i claimed a windscreen. Nightcrawler is a negative nancey 🤪
Yeah, Turbosmart e-gate seems the way if you really want to get fancy - though much can be achieved with a couple of 3-ports and a decent enough ECU as well.
Yep, the pneumatic wastegate setup is actually quite interesting. The problem is where you plan on sourcing enough vacuum to keep the wastegate fully closed for extended periods under boost. BMW used a vacuum pump + vacuum accumulators to make it all work. I can't imagine trying to package any of that in an RB turbo where it feels like the engine bay is already laughably packed.
