does anybody know which one is the fuel return line and fuel > engine line? why are there 3 hoses? how do i change these hoses? i think they are attached to the metal fuel lines under car but couldnt find the place they connect.
please help. thanks
https://www.sau.com.au/forums/topic/376124-changing-fuel-hoses/
converted to E85 so not sure if need to change these as well as ones in engine bay?
so the red circle is feed? blue circle is return and yellow is breather?
do i need to change the breather hose as well for e85 use?
thanks!!!
You don't need to change anything for e85, your lines are designed for e10 so will last many years with any ethanol percentage. What were you planning to use?
If you want to change them you will need a custom pump housing made so the teflon braided lines will connect to it using dash fittings.
