OK, So my r34 Gtt is in having a head gasket done and am planning on getting a Boost Controller on and Bosch Fuel Pump done also to run a lilttle more boost.
Going slowly, I eventually want to aim for around the 250 kw mark. I've read quite extensively on SAU on what I'll need to do to acheive this and have decided to go for:
Hyper gear Highflow turbo
Nistune ECU
Z32 AFM
Injectors of some sort
The car currently has 3" Kakimoto full zorst
Greddy FMIC.
I'm wanting some advice as to where to after I have the Boost Controller and Fuel Pump done, I dont have the $ at the moment to do all these mods at once but wanted to spend around $1000 on the next mod and wondering if I get the turbo high flowed?, Or go the Nistune first
Ideally I'd like the car to be safe and driveable before the next upgrade!
Any help appreciated.
Cheers guys.
https://www.sau.com.au/forums/topic/376151-r34-gtt-build/
Well you have two options if you want to buy the parts eventually then you can get the nistune first and get the car tuned how it is at the moment and then you will have to have it reutned again when you get the turbo or your 2nd option is to just buy the parts and dont put them on til you have everything and do it all in one go which will save you having to retune again. You can stick the new turbo on and drive around as it is but thats not ideal as its not tuned for it so I wouldnt be doing that.
https://www.sau.com.au/forums/topic/376151-r34-gtt-build/#findComment-5999475
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
