This is the 2011 MotoGP thread because much to my surprise we haven't got one.
Starting off, Casey Stoner cuts a pretty tidy lap to throw himself onto pole position for Misano tonight, who's watching ?
Anyone think Lorenzo can catch and pass Stoner over a race distance without some sort of bingle ?
Who will Simoncelli crash into this round ?
All these questions and more, ITT.
https://www.sau.com.au/forums/topic/376154-2011-motogp-thread/
  • Replies 486
Posted Images
I was gonna start a thread a while back, surprised there wasn't one this year..
Fell asleep and missed quali last night, but I'll be watching the first half of the race up until I have to leave for work, and the second half tomorrow...
Also, not to be discounted Moto2 is some of the best motosport on TV!!
Im a huuuuuuge Marc Marquez fan. which is strnage because typically i cant stand spaniards, but WHEN he makes it to MotoGP, ill be cheering him on as much as stoner.
Special shout out goes out to Crazy Jo too! lol the lewis hamilton of bikes
Stoner with the new lap record.
He annoys me though ever since he pretty much called rossi a hack. Casey 9 time world champions across various classes are not hacks you f**king idiot.
Maybe, but after Rossi & Burgess spent months telling anyone who'd listen that Stoner hadn't ridden the Ducati to its potential; in spite of the fact he's the only rider to consistently win on it. And for all the big talk in the pre-season, they've produced precisely nothing in the way of results.
They've been pretty quiet about his ability lately...
Rossi's no hack; that's for sure, but he's closer to the end of his career than the start.
Edited by Daleo
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
