Just wondering if It's possible to replace the factory ceramic exhaust wheels on the R34 GTR turbos for steel ones to make them pretty much N1's? As I've seen the steel wheel rebuild kits on ebay for r32 and r33 turbos but not r34. Has anyone done it or know what it would cost if It's possible?
Thanks
It is possible, but that doesn't make them N1s. I believe rebuild cartridges are much more expensive for 34's as they use ball bearings, and since N1s are only 2200 nobody bothers since it works out about the same or close enough, especially once you take into account the installation cost.
Well that's my recollection of what I was thinking before i bought -7s.
It's your call but IMO for the expense/effort involved in removing and replacing RB26 twins , and rebuilding bush bearing cartridges , I'd prefer new ball bearing units .
Perhaps you could enquire about buying cartridges used in the 707160-9/GTSS turbos but when I did a few years back they were not available as cartridges only .
Off the top of my head R34 BB turbos are a GT2556R and while they may be rebuildable with steel turbines I think the best direct replacement is the -9/GTSS because they are an RB26 specific turbo rather than some generic variant .
Yes they cost a bit of cash but imagine what it would cost to remove and replace rebuilt plain bearing turbos again if you damaged one .
The bottom line is that well designed ball bearing cartridges are a lot more reliable long term if they are not abused and the engine serviced properly .
RB26 twins are a major PITA to work on/around so you want to minimise the need to R/R them unless you are rich/someone else is doing the spannering/it's not a daily driven car .
Do it once do it right .
A .
Garrett uses Inconel wheels on their BB turbos (-7, -9, -10, -5, and most likely R34 N1's), pretty sure Inconel is a heck lot lighter than whatever grade of steel the "N1 spec" kits use.
"N1 spec" with thrust bearing + steel wheel + even with the smaller housings, the genuine R34 N1 would easily outflow them and most likely even be less laggier.
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
