Hi Alex,
It's a 1953 XK120 DHC. We are converting it to RHD. I believe ya mate because I too know very well there is alot of fixing. Especially due to the price range my dad buys them at :) They are such a rewarding car though that they are a pleasure to work on. Removing all the paint off the alloy bonnet and doors was just awesome. Removing the siezed door hinges and repairing was an absolute pain but a joy now that it's done. I could go on for hours on the things we have done so far just on one car. What car's did/does your dad have ?
Grew up with Rovers- P6B mainly, went through about 3 or 4 of them, then onto the honda rovers - quintet, 416, 827, and still has a 75. There was a daimler sovereign (like the 420 compact), a Mark1 Jag, nut and bolt (over 20 years...lol) resto on a MG A, MG Magnette was a bit before my memory, and finally he still has the early MGB GT, that his father bought new in England in good original condition.
He has a NA MX5 these days for the topless fun, all the joy of the MGA, without the pain.
+2 for liking the Chaser. Saw a JZX110 in Dandenong late Wednesday. Did like. Would consider buying if I didn't need/want a wagon.
Same; the boot was just too shallow for me; otherwise I'd be hitting some 1JZ action. The late model vvti single turbo 1JZ's are a much nicer thing to play with.
I still don't think the interiors are quite up to the standard of the Nissan though.
not really, i chipped my current car and its more economical and has more power............ :P
Gotta love the VAG cars for that. What chip did you get / who did it for you Iain, & what gains did they advertise for your car?
I bought the missus a A3 Tdi (125kw / 350Nm std) which I'm trying to convince her to let me upgrade the 'economy'. Most I've looked at don't get a lot more power, but some (supposedly) have as much as 77Nm gain - & that's significant considering how little effort it is to get it done.
+1 Iain; What did you end up using, and what is the end result?
Did you do any supporting mods?
Details man, DETAILS!!!
i got a 2nd hand superchips bluefin for $550. they offer a stage 1 (no supporting mods required) which does 54NMs more and 41HP. stage two can offer half again as much, but need fuel pump, dump pipe and intake. took 3 mins to reflash via a hand controller. ive done no other performance mods to the car. only HID conversion ($2.5k for HID pffft) and a fully integrated ipod interface to the satnav system.
leon, your wifes A3 if its more than 3 years old can do a remap via the consult, however all the new diesels (like andys) need to have the ECU removed and perform a bench flash.
i get boost from about 1500rpm and it wheel spins in the dry around 3k into 2nd gear. wet weather, forget about it. however this is a FWD car :( but it handles VERY well for an ass dragger. the sydney people will see it next weekend if they come to the meet
Edited by zei20l
That's a good price Iain. My preference so far is for Bluefin, but pretty pricey here in Aus. I don't know if I can buy it online from UK (running a special there atm) or if they'll insist I get it here.
And yeah, it's more than 3 yrs old so ridiculously easy way to gain some more grunt, umm, I mean better fuel economy, lol.
then you shouldnt have a problem with a reflash!
i got mine from www.vwwatercooled.org.au there is a good FS section there. i think the diesel engines have a good support forum too.
hahah sometimes economy=power. i can consistently get 10L/100km to and from work. highway, 6.5L/100km
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
