Hey everyone I have I issue with my rb20 to start with it has stock ecu custom front facing plenum rb25 turbo with bigger compressor wheel and op6 turbine housing welded wastegate highmounted, turbosmart external wastegate 35mm, walbro fuel pump and 32 gtr intercooler with piping to suite now my problem is the car will start and sometimes hold idle and when it does hold idle It hunts really badly revs go from 1000 to 2500 and just keeps doing it and I'm fairly sure it's not the air flow sensor because it will rev over 2500 with no restriction iv replaced the plugs and one of my knock sensors was broken so I got a new one iv cheeked all sensors are connected and iv cheeked for vacume leaks but can't find any I really need help on this one. What could be causing this?
Hey mate I just noticed on your status that you do nistune on the coast and once this problem is fixed I'm looking to get a tune done where abouts are you located on the coast?
OK so the car wll now idle propely I'm putting it down to having the idle sensor in the wrong spot but I still have the problem of the car stalling unless I hold the accelarator on so I got the shits and decided to check the ecu codes and it came up saying the tps sensor is dead so I checked all wiring looks good now I'm guessing it has to be the sensor itself. Can the sensor be fixed or should I smash it with a hammer and buy a new one and fit it's a new one how much are they and does anyone have one
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
