Hi all, just wanna make a quick question about the factoy bose unit on the 2003 V35, is it common for the 6 discs cd stacker to break or jam?? and is it a easy fix?? I have done abit of research and found some horrible stories, that a faulty cd stacker could lead to A/C malfunctions and battery drains and other disastrous scenarios...I would like to know if these are just some extreme cases or a common issue which most owners experience, only reason asking is bcuz I have looked into buying a 03 model v35 skyline and the cd stacker happened to be apparently "jammed" with error code F0 or soemthing...dont really mind if its an easy fix but if it is a quite seriouse issue then i might have to reconsider...
owners comments and experiences would be greatly appreciated
thanks all
https://www.sau.com.au/forums/topic/376211-cd-stacker-issue-v35/
VERY common. I get a call a week asking for a way to fix them. parts are not available for them due to age and the best solution is to rip the lot and sart fresh.
happy to elaborate on it if you wish.
so i guess double din unit and the facia kit is the way to go, just wondering does the factory pop up screen still work after the conversion? or does it become completely useless?
I went with a CarPC, and left the dead CD staker where it was. I can also switch over to the inbuilt nissan computer for fuel economy and service intervals etc
And if you get the correct cable from Chris ^^^, you can plug whatever device you like into the factory tv :)
I have my CarPC plugged into this screen using a cable from Chris, and also a reverse camera which switches over automatically when you put it in reverse.
So the factory screen is very useful. My center console looks completely stock, and it all tucks away as original.
BFH! (Big Fkn Hammer.)
seriously it is full strip down of the thing and at the end of it the unit is a throw away. this depends WHERE the transport has locked up. some are easy to strip others you will destroy pulling them apart.
time to bend over and take it like a man :P
its a new panel,ac controls, bose lead and SWC unit then a new radio then its fixed. its not going to be a cheap exercise.
There is a how to on the removal of the CD's on youtube
Chris - With the cartridge removed as in the video, will the radio, tape, AC etc still function or is there a self check it does that will make it spit the dummy?
I'm going to have to decide whether to add Ipod interface or do the financially painful change to a double din setup. Not looking forward to it.
it will run without it BUT the ipod lead that I sell will not work as it disables the port that it plugs into if you remove it. there is a trick to it but it is at board level and I do not wish to disclose that for the express reason people will start harassing me when they destroy a board whilst trying to mod it.
Mark, buy this
http://cgi.ebay.com/...=item3cbbeb0f3c or a new one = $300 shipped these days
and this
http://www.skylinesa...04#entry5994404 ---> similar to what I have and is AWESOME!
= profit!!!
Looks good. Is that a Metra Kit or Original?
How well does the colour matching with the G35 kits go with the V35 interiors especially on a 2001 300GT?
Edited by o2bfit
That is a 2nd hand original kit. DON'T EVER CONSIDER USING THE METRA. It is a pos. You can spot the Metra rubber buttons a mile off - they are crap and apparently the climate units are know for failing.
Colour match is perfect on mine.
Question regarding the interior colour. The interior of the my 2001 300GT console is a dull khaki dark greyish colour which I assume is Willow (its certainly no silver or black). There appears to be differences in the jdm colour advertised on ebay, some mention it is a silver/willow, some willow has dark grey on the vents.
This is the closest I've found to my interior but the seller won't ship to NZ.
Does anyone have any information about the interior colours available for the V35 and G35?
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
