Hi all,
I am getting idle issues whereby the idle and voltage meter of the car sputters/goes between 500rpm to 800rpm when I turn the A/C on. Be it on low or high setting. Turning the heater on the low or high setting doesn't do this. The car idles fine otherwise. I noticed sometimes if I'm at the traffic lights, it may go below 800rpm at idle for a brief few seconds and go back to normal, but only if I press the brake pedal a little too hard. I've recently put in new NGK IX spark plugs and checked all the coil packs.
Could this be an ACC problem or do I need to get the A/C re-gassed? The A/C works fine other than causing the idling issue.
https://www.sau.com.au/forums/topic/376243-rb25det-idle-issues-with-ac-on-only/
will most likely be the AAC valve. the AAC valve (auxillary air control) adjusts when things like the aircon is turned on, or the steering turned, as there is a higher load placed on the engine so the ecu compensates.
look in the DIY section on how to clean the AAC and see if that helps your issue.
