So today I discovered the present I was left presumably from after the dyno day when I stopped for lunch as thats the last time I drove my gtr. I would have been out of my car for no more than 10 minutes but that was all the time the f**king scumbag needed to hit my car and leave without me noticing. The dent isn't too bad really but the paint scrapes they left are my concern. Anyway a picture tells a thousand words so...
the dent is a little hard to see, as I said its not huge.
So I need some recommendations from people who may have used those dent removal services before or whether its something only a panel beater would be able to fix. I'd really like to get it sorted before the dawn cruise.
Cheers,
-Pete.
https://www.sau.com.au/forums/topic/376247-dent-removal-in-adelaide/
you can use simple Thinners to remove the paint marks, and a small amount of dry ice to pull out the small dent
are u serious??? thinners, ummmm NO!!! thinners wil remove the clear also, just use a gentle cut n polish to get rid of the paint...
as for the dent i use "adams dents".... look him up as i dont have his number handy, my x gf's black astra convertable has the rear qtr kicked
and this guy got the huge dent n scuffs out without a mark left, i was impressed.. all for under $100 :)
any probs sourcing his number im sure i can chase it up for u... hes mobile also
Edited by kh6gtr
So just got the car back from Nick with Dentmasters and its perfect.
I wont bother taking a photo because you cant tell that there was a dent there.
He was very easy to deal with too, good bloke.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
