Hi thought id ask here before i pay $150 for the audio shop to put the headunit in.
I bought a JVC SHX855 headunit and for some reason no matter what i try i can't get any sound coming from the speakers? The headunit turns on etc etc and everything works within it but just no sound.
My cars a 1994 r33 4door gts.
But i tested something. if i run one of the headunits speaker wires through the blue/white cable on the headunit (its called amp turn on wire) i get sound?
do i need to wire up the blue/white wire to something?
I really don't want to pay $150 for the audio shops if its simply join it to a wire which is sitting right infront of me.
Oh and the previous owners cut the wires so i don't have the original plugs which sucks.
Edited by corpse.
https://www.sau.com.au/forums/topic/376269-headunit-no-sound/
You must have it all wired wrong. What you can do is get a 9v battery and with the car off connect it to what you suspect are your speaker wires(make sure the deck is unplugged). You should hear a pop in the speaker. If you do not hear a pop then you are not connecting the right wires.
Are your speakers wired to your head unit or are they connected to an amp? Did you connect any RCA cables? By the sounds of it, it sounds like your speakers are connected to an amp and you are just not giving the amp the power wire(its blue I think, just double check, blue white is usually antenna power). If they are amped up, make sure the RCA's are connected and you are giving it amp turn on wire.
Any non f**k around audio shop will do this job for $60. Unless of course they need to run new wires to every speaker which isn't likely.
Edited by SargeRX8
im running the speakers off the headunit. the previous owners had a crappy old kenwood headunit and cut the wires. Only thing i can think of is that the car use to have a factory amp but it was taken out?
and theres only 1 place in town that does the audio installs and they are charging $100 for the install + if they need to run any new wires etc etc
Edited by corpse.
    • That's awesome. Fully serviced/full log book history for one of those cars is super rare from what I know. With JDM's like Skyline's, Supras, are quite hard to find one with full log book history. S15's seem to be somewhat of an exception, at least the spec s australian delivered models.
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
