i like the gold annodised centers. or just black?
CCW WHEELS
Can you please tell me how it feels when you go over pot holes? Isnt that wheel hanging out of the guard which means the guards are going to be f*ked up soon :s
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6023068
dave, that set on the 32 with the dark grey centre with polished lip look sexual. like BBS LMs (probably one of my fav R32 GTR wheels) but with nice curve in the centre to give it some depth.
you could try 11s but will definitely need some careful offset choice and at the least rolling/folding the guard lips and possibly even a little bit of flaring (doubt it though). fronts will be the same. need to fold the lip for sure and possibly remove the guard liners or at least modify them (can heat them up and re-shape them a bit).
I'll say it again, they look hot. 18X10.5 or 18X11 with somewhere between +15 and +20 and you should be right. could order them in +20 or so and adjust as needed with small spacer.
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6023623
good choice mate. 17s look way better on R32s. all the tough R32s in japan run 17s. I once asked a mate why and he said (my rough translation) "it just looks right/proper/correct". :)
the only reason I guess most go 18s in for brake clearance but the right 17s can still fit some pretty serious brakes. my F50s with 355mm rotors fit easily under 17inch Nismo LM GT4s with a lower profile caliper I reckon you could get bigger rotors under there.
I do like the teddy bear wheels. tough call really between those and the CCW.
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6033618
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
