i like the gold annodised centers. or just black?
CCW WHEELS
Can you please tell me how it feels when you go over pot holes? Isnt that wheel hanging out of the guard which means the guards are going to be f*ked up soon :s
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6023068
dave, that set on the 32 with the dark grey centre with polished lip look sexual. like BBS LMs (probably one of my fav R32 GTR wheels) but with nice curve in the centre to give it some depth.
you could try 11s but will definitely need some careful offset choice and at the least rolling/folding the guard lips and possibly even a little bit of flaring (doubt it though). fronts will be the same. need to fold the lip for sure and possibly remove the guard liners or at least modify them (can heat them up and re-shape them a bit).
I'll say it again, they look hot. 18X10.5 or 18X11 with somewhere between +15 and +20 and you should be right. could order them in +20 or so and adjust as needed with small spacer.
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6023623
good choice mate. 17s look way better on R32s. all the tough R32s in japan run 17s. I once asked a mate why and he said (my rough translation) "it just looks right/proper/correct". :)
the only reason I guess most go 18s in for brake clearance but the right 17s can still fit some pretty serious brakes. my F50s with 355mm rotors fit easily under 17inch Nismo LM GT4s with a lower profile caliper I reckon you could get bigger rotors under there.
I do like the teddy bear wheels. tough call really between those and the CCW.
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6033618
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
