i like the gold annodised centers. or just black?
CCW WHEELS
Can you please tell me how it feels when you go over pot holes? Isnt that wheel hanging out of the guard which means the guards are going to be f*ked up soon :s
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6023068
dave, that set on the 32 with the dark grey centre with polished lip look sexual. like BBS LMs (probably one of my fav R32 GTR wheels) but with nice curve in the centre to give it some depth.
you could try 11s but will definitely need some careful offset choice and at the least rolling/folding the guard lips and possibly even a little bit of flaring (doubt it though). fronts will be the same. need to fold the lip for sure and possibly remove the guard liners or at least modify them (can heat them up and re-shape them a bit).
I'll say it again, they look hot. 18X10.5 or 18X11 with somewhere between +15 and +20 and you should be right. could order them in +20 or so and adjust as needed with small spacer.
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6023623
good choice mate. 17s look way better on R32s. all the tough R32s in japan run 17s. I once asked a mate why and he said (my rough translation) "it just looks right/proper/correct". :)
the only reason I guess most go 18s in for brake clearance but the right 17s can still fit some pretty serious brakes. my F50s with 355mm rotors fit easily under 17inch Nismo LM GT4s with a lower profile caliper I reckon you could get bigger rotors under there.
I do like the teddy bear wheels. tough call really between those and the CCW.
https://www.sau.com.au/forums/topic/376294-best-rims-eva/#findComment-6033618
