Well I finally put a new head unit in my car;
runs the Bose amps and speakers: tried the Metra 70-7551 but found the sound quality was woeful; swapped back to the Japanese harness that was being used on the Carrozzeria system that was already in the car
Sony XAV72BT - US Model (I wonder if I can make it DVD region free easily... no idea and not to bothered if I cant)
Also installed a reversing camera and got the steering wheel controls working (PAC-SWI-PSv1)
Next step on the Audio front will be to add a digital TV Tuner (and maybe a front camera: I just need to find a way to easily switch between the two cameras on one RCA input), and looking at if its possible to give my car back its dual zone climate control (G35 forums suggest its just soldering on an extra button and replacing the blank?)
Pro's of this head unit: dedicated reversing camera input + reverse trigger
excellent bluetooth handsfree (better than the dedicated Nokia one in my last car, and better than all the ones I drive in hire cars - current falcon/commodore/ i45/corolla/xtrail)
cons: slow over USB (slow to change tracks etc)
region locked to USA (but its half the price of an Australian one!)
Anyway less talk more photos: Not bad for a total cost of about 600 AUD
Looks good mate. Did you install the steering wheel controls yourself? I have the actual steering wheel control module installed on my steering wheel, and I have a SWI-PS1 with wiring diagram, but I don't actually know WHERE the plug is that I need to connect the resistors and patch into.
Nice. I have been trying to decide if I should go with an aftermarket head unit or get the iPod interface. I know the iPod I/F would be cheaper, but I like the idea of a reverse camera and bluetooth HF.
Just wondering why you went with the non-dual zone AC controls? Can't you buy the controls to suit the dual zone setup?
Also, what else was required to interface to the factory bose amps? You said you didn't like the Metra and just used the factory harness. Did you need anything else, other than the double DIN surround and AC control unit?
Sadly the Nissan dual din kits do NOT come with dual zone climate - dual zone are not made in a single din interface. But as Glen pointed out all you have to do is unsolder the dual zone button and assembly off your stock BOSE setup and solder it into the new climate controller (there is a blank spot for it).
Nice install Glen :thumbsup:. I love the look of a dual DIN headunit.
If you don't have enough A/V inputs for the DTV tuner & front facing camera, the tuner has an input that can easily be switched on/off (so you get both functions on the one input on your headunit). Alternatively you could use a couple of relays to do something similar, but if you were going to get a tuner anyway.....
they are actually. thing being they are almost twice as expensive as the single unit. every once in a while I get a request for it and that usually follows with a heart attack once they hear the price.
Maybe Chris can answer this question - where is the plug I need to tap into to get the steering wheel controls working?
behind the radio. its the 3rd white plug that was in the stock clarion unit. I have a interface that will do away with the resistors. it simply wires in and works.
Hey guys,
Haven't been on the net for a few days (Did a trip from Mackay to Capella for work and had a few network installs along the way)
Chris is 100% right, its a plug that looks very similar to the one that plugs in to the climate control
I merely found some wire the same colour as the ones I was tapping and went upstream to preserve the original connector - if you can buy a plug in adapter from Chris then do it! - I used lengths of wire and shrink wrapped the whole thing up because that is just good practice.
I had it really easy considering there was already a Pioneer/Carrozzeria unit in the car, so I didn't really need to buy any adapter harnesses (though I bought a Metra 707551), and I already had the dash surround
I would advise against buying a Metra 70-7551, as it sounds like crap! I had it in there for a couple of days before I could get my car into my Father's shed and actually do things properly, and the difference was night and day (to the random harness that came in the car from Japan)
I'm sure either Chris or Commsman will supply a kit to wire an aftermarket head unit into a V35 with Bose audio controls
Also pulled about 5kg of wire (no joke) out of the car that was associated with my standard antennas, (and the GPS antennas and God only knows what other antennaes were previously on my dash) it did laps around the car under the carpet.
If I had my time again I would have bought an ebay camera that clips in where the number plate light goes. Coworker gave (or lent... I'm not sure) me one this week that he bought from ebay for a Z33 and it looks like it will fit our cars
Sounds like I'll go for the tuner and front camera then :D
Just got the front windows tinted on the Skyline today too (haven't seen it all week since spending half the weekend working on it)
  • 1 year later...
Hi All, any help regarding DD conversion would be great at this point this is what I'm going with....
Metra 70-7550- Wiring harness? Or PAC ROEM-NIS2 - Not sure which one I need?
JDM DD Facia - http://www.ebay.com/...6ddc43f&vxp=mtr
and the Ca-Fi Dashlinq (Unless anyone can give me any other great alternatives??)
Nissan Antenna Adapter
Is there anything else I really need to do the conversion? I mean I intend to get Tonkins here in S.A to install it, but is there anything I've missed other than the wiring harness? the JDM unit comes with the A/C controller.
Let me know what you think,
  • 4 weeks later...
Big Ups to John From Marvey Tech!!!
And thanks to nightcrawler for the excellent advice!
John did a wicked install on my dashlinq, it was just lucky enough that it fit the double din fascia pretty snuggly!
Marvey Tech! Adelaide no two ways about it!
Hey Mate,
Are you able to post pics of your install?
What i mainly want to know is does your oem Nav screen still work? If so, is your headunit able to output video to it via rca?
What i want to end up having is a double din headunit which is able to output or mirror its GPS onto the OEM Nav screen.
Cheers,
  • 4 years later...
i have a 01 250gt with non bose headunit with no steering controls , Do i need any special harness to install an aftermarket headunit or is it plug and play??
Edited by batron
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
