Instead of a supercharger supercharging the air going into an engine what about sucking the exhaust out of an engine. You would put this post turbo on a turbocharged car as these are the type of engine that would greatly benefit from lower back pressure.
Has this ever been done, would it be effective?
Discuss.
Edited by Rolls
  • Replies 65
You could use a cheap 'smog pump' from a US wrecker as in essence it works like a supercharger on the exhaust gases. Would have liked to hook one up to my old motorbike intake, run off a airconditioner pulley motor. Could use this theory to help evacuate exhaust gasses quickly as per your thoughts. Wouldn't cost much to fabricate & try out.
I can't imagine the pipe work. If its electrical it would be hard to setup and it is going to have to be designed VERY well and suited to each engine. Too many factors. The more boost you run means more fuel means bigger combustion means more exhaust, what if this thing can't suck the exhaust as fast as the engine is shitting it out? It would end up being a restriction. What if it spins too fast and creates a vortex of turbulence against the exhaust wheel of the turbo... Or maybe it can assist in spinning the exhaust wheel and creating faster spool time.
Interesting suggestion, but what's the idea behind this? Improvment of pressure differential across turbine stage of a turbo? It may benefit turbo itself, e.g. make it spool faster and use much smaller wastegates, but I can't see it adding any power to the engine?
i don't think this would work or have any kind of benefit at all. The turbine on the turbo uses the 'free' or unused energy that the fast moving exhaust gasses produce to in turn feed more air back in. I don't see any net advantage to use energy derived from the crankshaft to help spool a (turbo) - might as well be a supercharger from the beginning.
edit: before the so called experts see this thread and try to flame the OP for even suggesting it ("nissan spend millions in R&D and if it was such a good idea they would have done it before u so stupid") - lay off him, he's just having a crack and there's no harm in it. If you feel so strongly about it politely post the physics based reasons why may/may not work.
Edited by karma_syke
lol.
I can't believe some of the questions that get asked here, and then we get told not to flame.
Ok, I'll make up some good ideas on the spot:
1. Why don't they just make pistons out of titanium?
2. Umm, why can't we just make a way to burn water instead of fuel? Its cheaper?
3. Why don't we replace spark plugs with plasma torches? You'd get better ignition?
4. To save problems with gearboxes, I'm going to try and just take away the gearbox, and make my engine rev higher, to say, 30,000rpm. Then we won't have to worry about breaking the gearbox?
5. Why aren't superchargers just electric? Thats easier right?
oh, and look what I did to my turbo to make it better:
"nissan spend millions in R&D and if it was such a good idea they would have done it before"
Rolls what kinda drugs do you take man, i need some :banana:
Rememember a supercharger = infront of the heat, not behind it. That is going to be the typical enemy.
All a supercharger does is pressurise the intake, same as a turbo. Its just doing it mechanically rather than turbine based.
Superchargers given mechanically driven = off the motor. How do you intend to get the belts behind the exhaust manifold area?
In theory you would have to have the 'pump' very close to the turbo/dump area. As the exhaust gases rush out they rapidly cool so by the time you get past the cat and to the back part of the exhaust system [unless you have very restrictive mufflers] their is a heaps of 'extra' room and even some negative pressure.
Your dump is 90mm, your exhaust is 90mm and the air is cooling and contracting = the largest pressure is at the turbo exit.
But tbh, I think any mechanical advantage would be beaten by the turbulence created by the pump.
You might be onto something here :thumbsup:
Nissan did spend alot of money but there are certainly things they could have done better... Do you think they tried and tested the RB as a non interference motor?
The engine need inlet manifold boost pressure to carry out the more air burn more fuel = more energy theory. By charging the exhaust it can virtually lower exhaust pressure after the turbo.
Ie. I run 24psi out of my pretty quite exhaust and I have 6psi in my exhaust by 7000RPMs, Using a very powerful exhaust charger I can get it down to maybe 1~2 psi, might alter tinny bit on the dyno reading up top. How ever running it along would give similar effect as a big exhaust perhaps.
Also to get a electric charger powerful enough to produce or suck 6psi you are going to need a 8.4HP electric unit, run that into a 12V setup the current draw is about 600amps? (not exactly sure). Might require less as the dispatching requires less energy then compressing.
Try it out and prove it works or not. :thumbsup:
Whatever benefit it gives, would be removed by the energy consumption IMO.
Consider that the principles behind supercharger and turbocharger are forcing more air and fuel into the engine for the purposes of greater combustion forces upon the pistons, in an atmosphere where ordinarily the amount of air and fuel intake is limited to the vacuum and capacity of the engine. It doesn't really work the other way, when you have no combustion for exhaust gas stroke - all you are doing is extracting exhaust from the cylinders, which the engine has no trouble doing, given exhaust valves open as soon as the exhaust stroke begins.
As for spooling up a turbocharger faster / pre-spooling it...could work with properly designed plumbing...but I doubt the benefit/consumption equation would work out. Consider how much air is being pushed out by the engine at 2000rpm to start spooling a standard Skyline turbo...your supercharger would need to pull that much out to make it worthwhile = fair bit of power to turn it that quickly.
As for solving back pressure issues, well you can run a 5 inch pipe and end up with zero...
The only advantage I could see to this, if the theory could be applied, is that you could have variable backpressure with controlled extraction of the exhaust gases via different operating speeds of the supercharger. Again, whether the benefits outweigh the effort or energy put into it, is another thing.
Better off focusing on a way to use unburnt fuel in the exhaust gases to further power the vehicle :D
No No No what you really need is a nozzle on the exhaust, this way you will get a huge forward thrust from the exhaust gases being blasted out like a jetstream. Then you would need a dual exhaust system to balance the power otherwise you would end up spinning out of control!!!
Lol guys this is just a thought experiement.
Seriously though it would work the same way a normal supercharger works except in reverse. Instead of forcing air into the engine it would create negative exhaust back pressure causing massive scavenging which would increase VE and cause more air to get into the cylinder. You would put it post turbo, eg after it so it would suck exhaust out, would probably help with spool but mainly at higher load where backpressure is high improving top end.
Being as it is a thought experiement I'd just assume it was powerful enough to suck the gas our and create negative backpressure, eg it wasn't a restriction. I'm not the first one to come up with this idea, do some googling there are quite a few discussions on the same idea.
I think the main reason it would fail is it has to suck out fuel AND air, where as a charger has to only push air normally. Has to move more than twice the volume of gas so would require far more energy. Still fun to think about things like this, keeps your brain working you negative nancys.
Or you could use this and get negative backpressure, that was the point, get it below zero.
Your just doing the work twice with that setup aren't you? i mean the piston itself pushing up on the exhaust stroke is just a big pump pumping the gasses out of the chamber.
No you'd be assisting the exhaust stroke by sucking the exhaust out, this would aid in cylinder filling and get more air into the engine.
That is just an engineering problem, you could use a shaft from the front area that runs to the end of the exhaust sucker.
lol.
Mafia you are probably the most negative person I have ever met, I've never seen anyone else post such negative bullshit in threads.
Edited by Rolls
Not quite sure how to word it, but...
Rolls, people are negative, such is life. I honestly though I came up with the idea for sequential turbo's, posted, and of course it'd already been done. You can only learn from asking, and some are better less negative/harsh teachers than others. I've asked much stupider things and learnt from my mistakes, but am better off/smarter from doing so.
I thought up an idea a while ago of a large tank (say 5 litres) hidden somewhere that stores vacuum under idle/cruise etc, then switches a solenoid at WOT to lower the dump/front pipe pressures for a split second to try help spool a turbo quicker. Don't know if it'd work, but thought it was interesting...
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
