Hey guys,
Have recently got a tear in one of the steering rack boots in my R32 gts-t, and have been looking around Perth for some to no avail.
I know there is a universal option but I'd prefer to leave that as a last resort, and if possible get some made for the car.
Obviously Nissan could get some in for me but also charge out the ass for it. Also checked Coventry's and possibly Repco? (I forget).
So basically wondering if anyone knows where in Perth or on the www I can get some at a reasonable price, or if they are the same as those off another car, possibly S13's?
https://www.sau.com.au/forums/topic/376348-r32-steering-rack-boots/
sorry to hijack thread but does anyone know where to get the boot from the gearbox to gear stick and the square boot thats bolted to the floor around the gearstick on a rb26. both of mine have split and got a oil leak :angry:
Why would you not go the universal option? I recently changed mine to universal boots (aproximatly $5 each from Veale auto Parts)might take an extra 2-3 mins of triming each at the most.
worth it in My humble opinion :)
^^thats what i did,veales in redcliffe havem
pretty sure nissan would be the only way to get a new one. maybe try just jap? either that or find a good second hand one, they usually last a long time.
Nissan or just jap/kudos motorsport
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
