Hey guys,
Have recently got a tear in one of the steering rack boots in my R32 gts-t, and have been looking around Perth for some to no avail.
I know there is a universal option but I'd prefer to leave that as a last resort, and if possible get some made for the car.
Obviously Nissan could get some in for me but also charge out the ass for it. Also checked Coventry's and possibly Repco? (I forget).
So basically wondering if anyone knows where in Perth or on the www I can get some at a reasonable price, or if they are the same as those off another car, possibly S13's?
https://www.sau.com.au/forums/topic/376348-r32-steering-rack-boots/
sorry to hijack thread but does anyone know where to get the boot from the gearbox to gear stick and the square boot thats bolted to the floor around the gearstick on a rb26. both of mine have split and got a oil leak :angry:
Why would you not go the universal option? I recently changed mine to universal boots (aproximatly $5 each from Veale auto Parts)might take an extra 2-3 mins of triming each at the most.
worth it in My humble opinion :)
^^thats what i did,veales in redcliffe havem
pretty sure nissan would be the only way to get a new one. maybe try just jap? either that or find a good second hand one, they usually last a long time.
Nissan or just jap/kudos motorsport
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
